Setting the governor on an H
John R. Brock
04-09-2001 10:59:48
I'm wondering how to measure the engine RPM so I can verify the governor high RPM adjustment. This is on a H with a magneto. Do I need any special equipment? And Yes I have some manuals on order if the ever get here.
Wayne Swenson
04-09-2001 21:36:54
 Re: Setting the governor on an H in reply to John R. Brock, 04-09-2001 10:59:48
If you have access to a mechanical tachometer, you can go to the belt pulley flange or PTO shaft to take a RPM reading. According to my Serviceman's Guide, the engine should run at 1815 RPM, the belt pulley 1121 RPM, and the pto 594 RPM when the engine is at fast idle.(wide open throttle --no load)
The engine runs at 1650 RPM when the throttle is wide open and pulling it's rated load. Idle RPM is 450. Hope this helps.
The Red
04-09-2001 11:40:15
John I usually just adjust the linkage for wide open. The most I have seen an H put out is around 2,000 RPM.
