Order Farmall Cub Parts Online
Need help bad, no fire to plugs on farmall cub 6 volt
georgia boy
04-09-2001 07:45:06
my cub has had a car coil put on it and ALL AT ONCE it stoped running, put in a new set of point and still can not get fire to plugs, the coil is firing good. also when i pulled the rotor off it turned and i guess it is out of time, could any one please help me. thanks, ga boy
TomH
04-09-2001 17:00:29
 Re: need help bad, no fire to plugs on farmall cub 6 volt in reply to georgia boy , 04-09-2001 07:45:06
I don't understand what you are saying. How do you know the coil is firing? Timing light on the high voltage wire? But no spark to plugs? Again with a timing light? If a timing light doesn't pick up a firing on the plug wires then timing is not the problem. Where is the current going if the coil fires but not the plug? Something shorted out in the distributor?
George Willer
04-09-2001 10:46:24
From your description, you must have a mag that was converted to work as a distributor. If I understood correctly, the coil was firing...the spark just can't find the plugs. This should work...Bring #1 piston to TDC on the compression stroke. Mark the location of #1 plug wire on the outside of the mag and remove the cap. Now remove the rotor and replace it so it points to the mark you just made. If the impulse is still working, and it was in time before, it should be in time and run. A true distributor doesn't have the geared rotor or impulse.
Dave T
04-09-2001 09:31:29
did you replace the condensor too????
The Red
04-09-2001 07:53:32
I am not familiar with the Cub ignition, but on the H there is a keyway that can shear which will throw off the rotor timing. You will probably have to remove the distributor and check connections from the back of the gear towards the rotor. Before you remove the distributor, I recommend you get the number one piston on top dead center on the compression stroke.
