Re: International 656 gauge help
Mark Robke
05-11-2019 16:48:22
Yes, you need 12v going to the gauge cluster. What makes the needle(s) move is the ground path goes thru the sender unit(s). The sender will vary its resistance to ground which in turn, causes the needle to move more or less to vary its reading. The voltmeter,if equipped, just reads + and - to show battery condition. An ammeter is in line voltage from the generator, or alternator, to the battery. An idiot/warning light has voltage to the lamp, and grounds thru the sender-no resistance-an oil light sender will be normally closed,and opens when oil pressure is built up. An coolant temperature light will be open to ground,and close, and thus light up at overheat temperature. Mark.
