Farmall 460
jeff
04-01-2001 10:18:09
what is approx. weight of the 460 with fluid in the tires?
Ross Sherrard
04-03-2001 18:34:04
 Re: farmall 460 in reply to jeff , 04-01-2001 10:18:09
We ahve a 460 diesel with narrow front, fast hitch, and 15.5.38 tires with fluid and it weighs 7120 lbs, have been pulling it in 7500 class.
crockofbc
04-02-2001 10:16:01
This is from the Nebraska Tractor Test No. 670. The total weight was 5835 LBS. No weights or liquid tire ballast was added. It was an F-460 gas with narrow front & 13.6 - 38 rear tires.
Split rear wheel weights are 63# ea.
Front end weights 125# ea.
front wheel weights 50# ea.
See message from Phil Auten(TX) titled "Weight chart for calcium chloride filled tires" posted on 04/02/01
Darin Johnson
04-02-2001 07:25:36
with 15.5.38 tires no other weights it should weigh about 7000-7500
