PTO Shaft Seal part number for a Farmal 300 Row Crop
Gibby
03-23-2001 17:49:53
I was wondering if anyone had the part number for the rear PTO shaft seal on a Farmall 300 Row Crop.
The last 5 digits are 43919 (I Think), I hit the part number with the punch getting it out. I was given a 470059-SSR from my IH Dealer, which is about a 1/4 inch to large on the seal portion - close enough that I thought it was the right size and took out the old one. HELP!
gene b
03-24-2001 02:51:16
 Re: PTO Shaft Seal part number for a Farmal 300 Row Crop in reply to Gibby, 03-23-2001 17:49:53
always measure od and id forget the numbers they are old and new ones are different and then mistakes are made so give the OD and ID CARQUEST in our area hasbetter seals than NAPA little more money but a much better seal been there done that
Joe Berendzen
03-23-2001 22:08:39
I don't know if it would be the same as a Super M, but I replaced mine recently. The original Chicago Rawhide No. was 45702-D, and the NAPA number is 13671. You might call them and have them look up the ID and OD to see if it may fit. Joe
Gibby
03-24-2001 06:20:16
 Re: Re: PTO Shaft Seal part number for a Farmal 300 Row Crop in reply to Joe Berendzen, 03-23-2001 22:08:39
I must say NAPA and or CarQuest is a lot closer than the 100 mile trek to the IH dealer. Thanks for the info.
