Gas Tank for Super C
SuperCmore
03-23-2001 07:27:07
Will a gas tank off a straight "C" or "B" fit on a Super C and look right? I can get one from a C worth the money, but will it fit OK?? SuperCmore
gene b
03-24-2001 03:06:28
 Re: Gas Tank for Super C in reply to SuperCmore, 03-23-2001 07:27:07
they are different the mounts are not the same you can make it work if you want to IF you want it original get the right one
I did NOT triple post
03-23-2001 09:39:24
#@%$ computers and internet service provider
Brackets
03-23-2001 09:29:10
Brackets are deeper on a Super by about one and half inches. The supers C radiator is taller along with the front middle section of the grill and this requires the gas tank to be mounted higher...if ya want to be factory perfect. If its a working tractor, use either as it can be "made" to fit. Got one myself that was made to fit. It runs and looks OK if you don't tell anyone.
farmer phil
03-25-2001 19:31:03
 Re: Re: Gas Tank for Super C in reply to Brackets , 03-23-2001 09:29:10
So that explains it!! When I was a kid back in the 60's, we put a radiator from an A into our Super C. The radiator was about 1 1/2" short!! Another one of lifes great mysteries solved. The things that you learn when you're not looking for them!! Thanks. You have no idea how good this makes me feel!!
Brackets
03-23-2001 09:27:08
Brackets
03-23-2001 09:26:51
Red Dave
03-23-2001 08:14:33
If I remember correctly from the super C I used to have, the tank is the same size, but, the mounting brackets underneath are different from a C. The super C tank sits a little higher to match the increased height of the hood, which is higher due to the taller radiator. The B tank mounts are like an A, which is different from a C or super C.
