Re: COMPRESSION TEST
Bama Binder
03-20-2001 10:29:40
Should be 120 PSI for 6.5:1 compression ratio...the distallate tractors will be slightly less. Most engines with some time on them will be lower. A lot of them will run fine in the 85-100 range provided you don't have too much knocking, smoking, plugs fowling, etc. The engine should be within 10% highest to lowest reading...regards...BB
