Hydraulics Questions
Jim
03-19-2001 10:54:04
I have an H w/ an M&W live hyd pump on it. If I have the breather screw open on the fill cap, it spews fluid when I use it. Is that normal ?
Also, it has a 1/2 inch input line to the pump, could that be the source of the slow cylinder movements ?
Thanks!
Roger
03-19-2001 18:54:12
 Re: Hydraulics Questions in reply to Jim, 03-19-2001 10:54:04
Jim, I have been using my hydraulic system on my Super H as a two way system with the return into the fill pipe. I had the same problem with oil coming out of the top of the breather hole. That hydraulic system is designed to vent out of that hole. I fixed mine by making a modification to the belly pump housing. I dropped out the pump assy, took the pump assy off the front (so I could get the shavings out) and then drilled and tapped a 1/8 inch NPT hole in the top of the housing. Then I screwed one of those hydraulic vents into it. I have never had trouble with oil coming out of the vent any more because it vents out the new vent hole. It is also clean since it is inside the tractor housing. Roger
