Order Farmall Cub Parts Online
Hydrolics for cub lo-boy
Tom
03-17-2001 04:17:18
I was told I need oil for my hydrolics. I don,t know where to put it. Can someone help a rookie please. thanks
Phlogiston
03-17-2001 16:14:56
 Re: Hydrolics for cub lo-boy in reply to Tom, 03-17-2001 04:17:18
Tom, on the left hand side of the travtor (if sitting on it), under the gas tank, you will find the hydraulic unit. On the lft side of the unit, you will see a fairly large hex head plug. Make sure it is very clean before you open it. Add IH Hy-tran fluid there. While the plug is open, move the touch control levers back and forth about 10 times and then add more fluid if appropriate. This will remove any trapeed air in the lines.
