Need solinoid for starter switch?
Author |
Nick
03-16-2001 18:10:36
I am planning to put a key start on my H. And just thought. Do I need a solinoid for this? I know its not original but Nether is any thing else.
big fred
03-16-2001 21:09:39
Re: Need solinoid for starter switch? in reply to Nick , 03-16-2001 18:10:36
As Dan said, the Ford unit should work fine. For some reason, Ford seems to mount theirs off the starter and call it a "relay" while GM mounts it on the starter and calls it a "solenoid". If you are running a 6V system, the Ford 6V relay also has a pushbutton on one end that can be used as a remote starter switch. The 12V versions I have seen don't have this.
Dan
03-16-2001 18:24:11
when i converted my smta to 12 volts I also went to a solenoid instead of the push botton on the starter. used a ford type solenoid. it has the 2 batter posts, in and out, then one wire that runs to your starter switch and the other is to bypass the resister when starting, you may not need it. anyway was pretty cheap.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
