Water pump grease nipple has stopped accepting grease
gibby
03-12-2001 12:59:11
The water pump grease nipple has stoppped accepting grease. I took the grease nipple off and it is passing grease. What could stop the grease slot from passing grease to the water pump shaft?
ltf in nc
03-12-2001 17:58:29
 Re: Water pump grease nipple has stopped accepting grease in reply to gibby, 03-12-2001 12:59:11
Take the grease zerk fitting out and try to run a small drill bit by hand into the grease passage. The passage is going to be small(1/16"or so) and most likey the passage is packed with old grease that has hardened or caked.
jerry gerthofer
03-12-2001 17:21:16
I would try a new zerk for starters
gibby
03-12-2001 13:05:39
On a Farmall 300 HC
Bill C
03-12-2001 17:03:33
 Re: Re: Water pump grease nipple has stopped accepting grease in reply to gibby, 03-12-2001 13:05:39
You are supposed to give it 1 or 2 pumps of grease,every once in a while. Too much grease,and it will get into the cooling system,and possibly clog the radiator**BIG PROBLEM**.
The Red
03-12-2001 13:56:44
Gibby I am assuming it is similar to the H. You probably have it as full as it can go.
jiM
03-13-2001 03:22:16
 Re: Re: Re: Water pump grease nipple has stopped accepting grease in reply to The Red, 03-12-2001 13:56:44
Red, I have always heard too much is about as bad as not enough on a water pump so I have always held this opinion in high regard. It would seem that in thw water pump situation as mentioned grease could get into the cooling system but also compression of too much could cause leaky seals, is this true.
jiM
gibby
03-13-2001 17:06:46
 Re: Re: Re: Re: Water pump grease nipple has stopped accepting grease in reply to jiM, 03-13-2001 03:22:16
After doing a root canal on the grease hole for the water pump, I found no old hardned grease. I was able to get down to the shaft (carefully) and could feel it rotate when I moved the fan. I guess to must just be full... Sorry for the alarm, but I keep the old girl greased up and this concerned me when it wouldn't take any more. Thanks for the advice.
