Battery Charging
Jim
02-03-1999 04:43:28
All I have for battery charging is a 12 volt "trickle"
charger.
Will I hurt anything on my 6 volt Farmall H if I use this to charge the battery ??
Thanks for your help!
Lynn
02-03-1999 20:02:32
 Re: Battery Charging in reply to Jim, 02-03-1999 04:43:28
Simply put, you may be able to get by with something jury-rigged for a while, but why not get a 6-12 charger.
Lynn
02-03-1999 20:02:18
Harvey
02-03-1999 17:32:35
Jim: I posted two hours ago but it didn't showup so I'll post again.. You said you have a "trickle" charger so if its less than 5 amps output when connected it will be ok but as Harold says K-mart has lowcost 6\12 volt chargers. The key here is low amps into your battery will NOT hurt it. Many tractors charge 2 to 5 amps all day and its OK for the battery.. but your charger may not like the mis-match long term. A 6 volt bulb in series will help the mis match..if the charger doesn't have good "current limiting" feature. harvey
jw
02-03-1999 06:24:34
Something you could do if you have another 6 volt battery, is hook the positive of one battery to the negative of the other battery, and then hook the charger to the remaining posts. By hooking the two 6 volt batteries in series like this, it is essentially one 12 volt battery.
Good luck
Harold H
02-03-1999 05:10:09
Jim,
The 12 volt charger will ruin (burn up) your six volt battery. You can get a charger with a 6 volt/12 volt switch for a resonable price at K Mart or Wall Mart.
Harold H
