Weel Weights
what was the original attaching method.
Gibby
03-09-2001 06:06:31
I just got a set of 150 lb wheel weights for the rear of my 300. I know trick of using treaded rod and attaching them, but out of respect for Mr. Verhoff (the original owner that painstakingly kept this tractor in such great shape) I want to keep it original. What was used to mount them from the dealership?
sammy the RED
03-09-2001 13:35:32
 Re: Weel Weights - what was the original attaching method. in reply to Gibby, 03-09-2001 06:06:31
3/4 x 4 3/4 NC sq. head like Mel said.
gibby
03-09-2001 19:14:47
 Re: Re: Weel Weights - what was the original attaching method. in reply to sammy the RED, 03-09-2001 13:35:32
Thanks for all the answers
John
03-09-2001 09:32:30
One uses 3/4" Carriage bolts of the proper lenght.
John
03-09-2001 09:39:11
 Re: Re: Weel Weights - what was the original attaching method. in reply to John, 03-09-2001 09:32:30
I may be wrong about the size but the bolts used were carriage bolts.
mel
03-09-2001 06:35:03
The parts book shows 4 square headed bolts inserted in the recessed square holes with a lock washer and washer on the inside of the wheel. That's the way they are mounted on my H. Second weights are mounted with 4 bolts in the opposite direction using the 2 holes and 2 slots on the edge of the weight.
