Resolution to Plow pulling to the right.
Gibby
03-04-2001 20:35:10
After a exhaustive process of checking each and every suggestion I got from my last posting on the issue, I found a solution. It seems that the right hand share was digging 1 1/2 inches deeper than the far left hand share. The fix turned out to be raising the draft control wheel on the left along with raising the manual Fast Hitch control arm adjuster to the maximum. In this configuration the tractor steered straight and was a pleasure to drive. Thanks for al the help guys.
dick
03-05-2001 17:16:25
 Re: Resolution to Plow pulling to the right. in reply to Gibby, 03-04-2001 20:35:10
Thanks for the feedback on what worked for you - lots of times that's what's missing on this board, and people are left wondering what the problem/solution really was.
John In Iowa
03-05-2001 05:18:14
GEE, I wish I was out plowing here in north Iowa. I know there is ground out there, but we haven't seen it since November. Good to here you found the touble.
John In Iowa
