Super M/M Transmission Parts Interchange Question
Andy Martin
02-26-2001 07:45:36
Took the belt pulley housing off a locked-up M and found a needle bearing from the transmission pilot bearing in the constant mesh gear. Both the constant mesh driving and driven gears have teeth missing.
I have a junk Super M, can anybody confirm that the transmission input shaft and constant mesh gears will interchange with an M? I don't want to pull the Super M apart if somebody with a parts book or first-hand knowledge can't confirm they will match.
This is one of my best M's, belonged to my grandpa, and I use it for custom baling all summer. I think the Super M rear end would fit on the M, but I'd really like to keep the major castings together.
By they way, the symptom of impending trouble was noise in second gear, only under heavy load, not just towing an implement. I worked it hard in third for six weeks every day after the noise in second started, and stayed away from second. The needle came out and started breaking teeth as the tractor sat at a fast idle while I was hitching an implement (maximum use of the pilot bearing). I could hear a few clicks. I shut it down, and the transmission was locked up tight from that point on, with a needle stuck between two teeth.
I should have stopped using the tractor with the sudden appearance of second-gear noise, but you get lulled into the excellent reliability of these tractors, including those that make transmission noise for years on end with no apparent problems.
Jim
02-26-2001 10:41:37
 Re: Super M/M Transmission Parts Interchange Question in reply to Andy Martin, 02-26-2001 07:45:36
The late M's have the same transmission driving shaft. What is your M's serial number?
Andy Martin
02-26-2001 11:47:41
 Re: Re: Super M/M Transmission Parts Interchange Question in reply to Jim, 02-26-2001 10:41:37
Serial Number is 219373
Thanks for the help
Wardner
02-26-2001 09:21:11
I have a SM book but no M book so I cannot cross reference. Below are some SM #'s
43 357 DA BEARING, pilot transmission main shaft
356 624 R91 optional with above
69 215 DA optional with above
356 676 R1 SHAFT, transmission driving (20 and 39 teeth)
ST 203 BEARING, ball, transmission driving shaft, rear (IH L-345)
ST 250 BEARING, ball, transmission driving shaft, front (IH GL-340)
48 717 D GEAR, transmission constant mesh (54 teeth)
