Best way to clean our unused threads in the transmmssion case.
gibby
02-24-2001 05:30:15
Looking for advise on the best way to clean out old previously unused threads in the transmission casing of my Farmall 300. I just added a 3pt add on hitch from Worksaver and the toughest part was cleaning out the treads. I ended up going to the hardware store and buying the closest tap they had and reaming the holes out with that and then getting several eight strength bolts and reaming the threads with them. The local hardware tap fit the hole, but it needed to be a tad bit larger to be able to deeply clean the threads. Bottomline is I got the top link mounted and life is good.
The reason for this posting is that I have do the same thing for 8 bolts for the fenders. Is there a better process and where can I find a tap that will fit deeply into the treads.
Thanks Dave Gibson
T_Bone
02-24-2001 06:25:28
 Re: Best way to clean our unused threads in the transmmssion case. in reply to gibby, 02-24-2001 05:30:15
Hi Gibby, Buy a bolt long enough the cut four slots along the threads just like a tap. They make great thread chasers and if harden, a tap.
T_Bone
George
02-24-2001 06:16:49
Gibby, If I understand you correctly, it sounds as if you didn't get a large enough/correct diameter tap if you are not getting the threads to clean up.If your problem is not getting threads to go deep enough in to the hole because the tap is tapered at the tip you can #1, get a bottom tap or#2, grind off the taper on the end and make it a bottom tap ..... hope this helps Geo.
RB
02-24-2001 06:03:15
Thats exactly what I did!I used a bottom tap.
