Pictures of NOS IHC marked Temp Gauges
justin
02-13-2001 20:48:24
third party image
Here are some pics of some NOS IHC marked Temp Gauges I acquired today. The 49040DB is for the H and M, and the 53619D is for the A and B.. If you look at the sizes of the IHC hark, and the Color zones, you will see that the mark is larger on the A,B gauge, and the zones are smaller. This is the same with the NOS 41934D oil gauge I have on one of my 39 Hs. I have been looking for these suckers for a long time, as nobody reproduces an IHC marked gauge that meets the quality I expect.. Best of all, these gauges work perfectly..
gene b
02-15-2001 03:50:39
 Re: Pictures of NOS IHC marked Temp Gauges in reply to justin, 02-13-2001 20:48:24
took one of a 40 B still works will check nos see how they match the B was a dual fuel
Chris Auer
02-14-2001 08:33:21
Made in Rochester NY! Don't you need to drill and tap the top of that little vertical cylinder on the front of the block, carb side?
justin
02-14-2001 09:26:15
 Re: Re: Pictures of NOS IHC marked Temp Gauges in reply to Chris Auer, 02-14-2001 08:33:21
On the A and B, there is a special lower radiator inlet that is drilled and tapped for the sending unit. The gauge on these tractors actually mounts up on the governor housing. The gauges were a special option, so not many tractors have them. They were more common on the kerosene & Distillate tractors..
Chris Auer
02-14-2001 19:20:48
 Re: Re: Re: Pictures of NOS IHC marked Temp Gauges in reply to justin, 02-14-2001 09:26:15
I saw a B at a show last Sept that had a temp guage sending unit on the top of that cylinder. It looked stock, and had me thinking about doing that to mine. I'd really like to know its temp; ie when I should let it cool down - running a liquid cooled machine without a water pump has a way of doing that! Thanks
BTD
02-14-2001 07:09:33
Justin,
Great looking gauges. I have been hunting for a temp gauge for my M. The cable is trashed on the one I have. Can you tell me where you obtained these?
Thanks! BTD
justin
02-14-2001 08:03:47
 Re: Re: Pictures of NOS IHC marked Temp Gauges in reply to BTD, 02-14-2001 07:09:33
They had actually been advertised on a web site for 3 years.. took a chance and called.. they cost me some money, but I think they were well worth it..
The Red
02-14-2001 03:40:35
I am not certain, but I believe one is for 160 degrees and the other for 180 degree thermostats.
justin
02-14-2001 04:42:05
 Re: Re: Pictures of NOS IHC marked Temp Gauges in reply to The Red, 02-14-2001 03:40:35
The A,B is 120-180, and the H and M is 170-200 degrees
The Red
02-14-2001 05:45:14
 Re: Re: Re: Pictures of NOS IHC marked Temp Gauges in reply to justin, 02-14-2001 04:42:05
Justin great looking gauges. That is a nice find!
justin pic
02-13-2001 20:53:22
third party image
here is the A & B
justin pic
02-13-2001 20:51:11
third party image
here is the H and M
