1456 Transmission
John Britt
02-08-2001 17:36:08
I have a 1456 International that jumps out of high 1st and high 2nd while under a load. I had some clutch work done on it recently and since then I have had this problem. Could there be a simple adjustment or will the tractor need to be split again? Any help would be appreciated. Thanks John
Jim
02-09-2001 07:29:52
 Re: 1456 Transmission in reply to John Britt, 02-08-2001 17:36:08
Is it jumping out of Hi range or is it jumping out of 1st & 2nd. I think it is a detent problem and you shouldn't have to split the tractor.
John
02-09-2001 15:21:16
 Re: Re: 1456 Transmission in reply to Jim, 02-09-2001 07:29:52
Jim, thanks for the quick response. It's jumping out of gear. At first it only jumped out of second now it jumps out of 1st, but only when I am in high range and under heavy load.
