What is a IH 656 Gas Worth?
Timsc
02-05-2001 15:01:34
I have an opportunity to purchase a 1966 656 gas with a loader. The 656 is a gear drive and it has been painted so it looks good. What is it worth and what do I need to look out for in this model?
al
02-06-2001 13:03:12
 Re: What is a IH 656 Gas Worth? in reply to Timsc, 02-05-2001 15:01:34
I have seen 656 Internationals for $8500.to $3700. It depends on condition. To professionally paint, overhaul engine and replace tires will run $6000. The TA might run $500. if it needs a complete overhaul. Perhaps you can do some of this yourself and save money but I find the most expensive work I have done is the work I do myself. Loaders are the same deal. $500-2500 depending on condition.
2 row
02-05-2001 18:49:49
You should check out operation of the torque amplifier and check for good action in the shift mechanism. Some of the early 656's had a tendancy to lock up in 2 gears at once! (shifter fork would jam) I would also check out operation of the pto, if at all posible, under load. Just curious, is this a row crop or a utility?
MIDUSS
02-05-2001 18:00:22
I guess it depends on where you are at. In Ohio a gas 656 goes for apprx. $3,500 to $4,500 and add $1,000,00 to $1,500.00 for the loader. The big thing to check with the tractor/loader is if the front end of the tractor is heavy enough to handle what you are lifting.
