1066 battery
R Rahmier
02-03-2001 16:58:13
The batteries on my 1066 are shot (2 long 6 volts)would a 1000 cranking amp battery work instead of buying these expensive 6 volts that only last a couple of years
ltf in nc
02-04-2001 07:02:09
 Re: 1066 battery in reply to R Rahmier, 02-03-2001 16:58:13
You did not state where you are located and the colder regions the lower temperatures need to be considered when changing the batteries. However, when you tractor was new the amps of 6 volt batteries was not all that high. Today a single new 12 battery can have more amps than two old 6 volts. You just need to be selective when you purchase the replacement. Here in N C, I have substituted a single 12 volt battery in all my 12 equipment that formerly had two batteries. I use Deka brand and I feel that these deliver the amps stated on the label. Never consider substituting car batteries for diesel tractor applications, you will only be disappointed. A single battery of high enough amperage will perform better for you than the original setup. Good luck.
DAVE
02-04-2001 04:09:31
I PUT ONE 8D BATTERYON A 966 AND PUT IT ONE THE SIDE OF THE FRAME USING ANGLE IRON AND DECK STEEL AND IT WORKS GREAT. IT IS ALSO EASY TO CHECK THE WATER AND CLEAN.
BJ
02-03-2001 17:22:42
I had the same problem. I mounted an 8d battery to the side of the frame. This is the same battery used in trucks and large tractors and should be available for about $110. I used angle iron to make the mounts. It has worked very well.
Dick
02-03-2001 19:41:27
 Re: Re: 1066 battery in reply to BJ, 02-03-2001 17:22:42
Did you hook the 8 and 6 volt for 14 volts for more juice to the stsarter ? Will the charging system bring them back equally ? Or will it over charge the 6 ,and not bring back the 8 to an 8...Just wondering whether I should try it or not.
Mudcat49
02-04-2001 06:44:55
 Re: Re: Re: 1066 battery in reply to Dick, 02-03-2001 19:41:27
Dick, a 8-D Battery is a 12 volt, it is BIG it takes two men and a boy to lift it!
