HELP PLEASE!!
Todd
02-01-2001 18:58:15
I have a 454 diesel. Listen closely, the tractor in low range will pull itself in 1st gear only, in high range it will NOT pull itself at all, and when the pto is engaged it will NOT pull itself in 1st low range. The tractor has a NEW clutch, NEW pressure plate, and the flywheel HAS been checked. Need some opinions.
'Bandit'
02-01-2001 19:32:48
 Re: HELP PLEASE!! in reply to Todd, 02-01-2001 18:58:15
See that the shifter is lining up and moving the correct gears, it could be moving in to a gear position but not moving the gear itself.
Just a thought, good luck
