IH 504 GOOD TRACTOR???
JOHN S
01-31-2001 19:26:28
I AM LOOKING AT A 504 GAS WITH A 2000 LOADER ALL HOSES NEW ON LOADER T/A 1 REMOTE IN REAR PWR STEERING 46 HP RUNS OK BUT SOME BLUE SMOKE. ARE THESE OK TRACTORS FOR GENERAL WORK AND LOADER USE STACKING ROUND BALES? CAN GET FOR ABOUT $5000. ANY COMENTS ON THESE?
gene b
02-02-2001 03:37:30
 Re: IH 504 GOOD TRACTOR??? in reply to JOHN S, 01-31-2001 19:26:28
where can you get that hp power steer a good loader ect for that kind of money sure things can go cheap at a sale I SURE WOULD LIKE TO HAVE 504 withall that stuff for 1800 but sure would not bet the farm would find one that cheap sounds like a good buy go see what 5k will buy for ttractor and loader
Mudcat49
02-01-2001 04:40:35
Way too much $$$$ for a 504. Although the 504 will do what you want it to do, If you are willing to spend that kind of $$$$ you can get a lot more tractor!
Wardner
01-31-2001 19:58:54
I have a 504 with a Great Bend loader and seven foot bucket. I have had it about 15 years. It only works about 100 hours per year. Has good hydraulics. Always starts and runs good. Never bought a part for it. I like the creeper first gear. Even though it is heavily weighted (sixteen wheel weights, loaded tires, and chains, it is nearly impossible to stall out. Nice to know it is worth $5000. I got mine for $1500 at auction.
Joe Evans
01-31-2001 19:56:16
Seems a bit steep on the price. Pop just got a 504 with a loader for $1800 about 5 mos. ago. It was pretty rough looking as it had a bad home, but otherwise runs OK. The 504 is around 44 horses, but uses the rather smallish H motor displacement. IHC just wound up the R's to get the HP. My brother says the 504 doesn't have much bottom end, but it runs sweet and handles well. I have no seat time on it to render a first hand opinion however.
tommyw
01-31-2001 21:11:26
 Re: Re: IH 504 GOOD TRACTOR??? in reply to Joe Evans, 01-31-2001 19:56:16
i have a 1961 504 lp. i use it almost every day .i built a forklift mast for it,on the 3point.it is a little weak on horses.im going to rebuild it and try to get a oversize piston kit. it is very reliable. have about 3000.00 in it (i paid too much) its probally worth 2000.00
Duner, Wi.
02-01-2001 06:41:08
 Re: Re: Re: IH 504 GOOD TRACTOR??? in reply to tommyw, 01-31-2001 21:11:26
Pistons or piston kits for 504 gas are not terribly common in the aftermarket. Best to line pistons up before hand. Have heard Allis pistons fit but may be a rumor.
The rest of internal engine parts are not a problem.
tommyw
02-01-2001 08:21:30
 Re: Re: Re: Re: IH 504 GOOD TRACTOR??? in reply to Duner, Wi., 02-01-2001 06:41:08
is it a super h motor? i thought it was?
Wardner
02-01-2001 09:00:43
 Re: Re: Re: Re: Re: IH 504 GOOD TRACTOR??? in reply to tommyw, 02-01-2001 08:21:30
The engine is decended from from an A or C. Many parts are interchangeble.
