Need new shift lever for JD350
BDCZ
04-10-2008 19:43:07
Anyone have a serviceable used JD350 shift lever for sale? I have the four speed tranny.
BDCZ
04-11-2008 19:08:26
 Re: Need new shift lever for JD350 in reply to BDCZ, 04-10-2008 19:43:07
Thanks CHinNY, I will contact you. Thanks too 135Fan, I was not aware that there was a used part network that dealers would be hooking into. I will check this out as well. This is great that there are folks like you two who can help a person out. My machine is in quite good shape the worst think being the worn shift lever. If I can find a new one it will make my machine really problem free. I hope to keep it running for many years.
135 Fan
04-11-2008 19:35:33
 Re: Need new shift lever for JD350 in reply to BDCZ, 04-11-2008 19:08:26
I had a 355 loader. I had it all apart and even put a good used shift fork in it. I even checked the shifting at the JD dealer before putting it back together. Dumb guy there said it was good. In the vice it shifted easier maybe because it wasn't hooked up the trans. gears. I put it all back together and I couldn't get it to go into 3 rd. gear. That's why I had it apart. I took the whole machine to the dealer and had to pay them to take it apart and find that the one shift rail was damaged and causing the problem. The service manager gave me a bit of a break on the cost but it still cost several hundred dollars if I remember right. I wasn't too happy. Dave
CHinNY
04-10-2008 22:23:23
I should have one email me for my web address and contact info
135 Fan
04-10-2008 21:29:45
See if a dealer has a used one or is hooked up to the used parts network. Shouldn't be too hard to find one. Dave
