D4 cat pony clutch pinion lever problem
mrleemus1
02-18-2008 06:59:28
Have i stripped the gear or what? When i pull up on the pinion lever nothing is there --- theres no resistance at all. with the pony running or shut off nothing is there. It used to grind a little then i could go ahead and pull it in. NOTHING THERE NOW -- what may have happend? Its a D4 2T2 series. Any thoughts would be appreciated.
Lee
Old Magnet
02-18-2008 09:08:20
 Re: D4 cat pony clutch pinion lever problem in reply to mrleemus1, 02-18-2008 06:59:28
Seems like the pinion engagement arm has either bent or broke inside the bell housing. Remove the little round plate on the clutch cover by your left foot and have a look in there. If you have been using the lever to hold the pinion engagement instead of the latches this is a common result.
JMS/.MN
02-18-2008 08:39:52
Pin sheared off in the lever?
