450c tranny
rick d
12-28-2007 08:20:57
my trac loader works fine in low range in all 4 gears but will not move at all in hi.Also i know how to set up the steering clutches but how should the sticks feel when its done right?
Roy Suomi
12-28-2007 13:22:28
 Re: 450c tranny in reply to rick d, 12-28-2007 08:20:57
Go to the archives about 450 transmission problems..I and learned others have helped others with the pressure problem sometimes associated with the transmission..On yours, I would start out with a gauge to check HLR pressures..And speed of shift adjustments are there too...Roy
jdemaris
12-28-2007 12:42:21
On the steering-clutch levers, there's no throwout bearing clearance to worry about since the steering clutches are hydraulically activated by the transmission pump.
You just want to make sure that at resta and for the first bit of travel - they allow full clutch pressure. And, when pulling back, the clutches fully disengage BEFORE the brakes start to grap. Easiest way to check is - drive the crawler up a steep slope. Then put it in forward - L with 1st or 2nd is fine- and go forward. While climbing forward, pull both steering levers back slowly. There should be a point where first the machine shops climbing, and when pulling back just a hair more -should start rolling backwards even though the foot-clutch pedal is up and all is in forward gear. If it doesn't roll backwards - then the brakes are grabbing too soon.
