1450B case Tranny need Help!!!!!
Rickey H
12-21-2007 17:31:37
We got a 1450b that has no low range, pulled the back of the tranny checked clutch packs, everything looks good. Checked with air sounds good. For heck of it I swaped the lines going to the lower shaft, now low range works good but no high, changed the hoses back, no low but high is fine . Took the valve body off cleaned and checked for everything I can think of, I don't have psi on the hose for low range out of the valve body. Any ideas? Help! Thanks Rickey
Rickey H
12-22-2007 18:41:25
 Re: 1450B case Tranny need Help!!!!! in reply to Rickey H, 12-21-2007 17:31:37
Thanks Guys, I only have a parts book and have already put on new hoses. Rickey
JCSinGA
12-22-2007 09:36:42
I chased a problem on a 1150B for a month. Would start out working fine but 15 minutes in one side would quit pulling. I done all you have talked about plus more. Finally changed a dadgum little hose and all is well, the inside of the hose was collapsing. Still makes me mad when I think about it. LOL
Rich in Garrett
12-22-2007 08:15:41
Ricky, you need to contact george in md. He's a friend. He's a case crawler guy. My bet is oil control rings on the clutch shaft. But you need to consult the Master if you want the straight skinny. If you have a service book, Case usually has a trouble shooting guide. We have a bunch of 1000's and 1150's, not sure the 1450 books are typical. I'd bet a dollar George can talk you down. Good Luck. Ps I sent you a mail, but I'm not sure what happened to it, so Here's a post.
uncle
12-22-2007 04:56:42
Not real familiar with machine but it sounds like the problem is following the range selector lever.
I would start there and follow it.
Brian
