2-stroke oil in diesel
Rob in Yukon
11-06-2007 14:04:03
Here's a topic for the forum members. I have been hearing about mixing two-stroke mix oil in uls diesel to lube pumps and injectors. I have several pre '90's diesels including a 7.3 in a Ford pu and a couple of John Deere's. What's the concensus? What's a good mix ratio?
caterpillar guy
11-09-2007 13:34:40
 Re: 2-stroke oil in diesel in reply to Rob in Yukon, 11-06-2007 14:04:03
I wouldn't use the ATF in onroad equipment likr trucks and such the fine for the red fuel would be more than the maintenance cost to use nothing. Which is what I do and have over 700,000 on my caterpillar truck engine. Never yet changed an injector. Sure now I will since I'm telling this.
(sonny)
11-08-2007 19:11:33
I prefer Lucas Fuel Treatment,more power,less smoke,better fuel millage ,no fuel pump problems,
I have john deere,cummins,case,caterpillar,engines.
also use Howes Lubricator Diesel Treat, does about the same as Lucas. available at most parts stores,
and farm stores. have used ATF as well other oils
with no problems. sonny
john_bud
11-06-2007 21:13:23
It seems to work well as a lubricant as the USLD is not as lubing as the old fuel was.
100:1 up to 200:1 are ratios commonly used.
Here's a link to some independant testing done.
http://www.dieselplace.com/forum/showthread.php?t=177728
Tom Spivak
11-06-2007 18:06:25
A friend of that's a GM diesel engine mechanic swears by putting transmission fluid in with the diesel at fill up, but I don't know how much.
MSD
11-08-2007 20:35:24
 Re: 2-stroke oil in diesel in reply to Tom Spivak, 11-06-2007 18:06:25
I read something on another board awhile back that you aren't suposed to use tranny fluid because it has an friction additive in it to make the automatics not slip.
steve n carol
11-06-2007 17:32:07
 Re: 2-stroke oil in diesel in reply to Dennis Sarver, 11-06-2007 14:04:03
Rob this subject came up on these forums just recently. Perhaps you can search this. try either the tractor talk or ford forums...sl
Marsh M. Ehlo
11-07-2007 06:47:05
 Re: 2-stroke oil in diesel in reply to steve n carol, 11-06-2007 17:32:07
I guess anything is cheaper than diesel nowadays.
