looking to buy a used Dozer
Ash
10-09-2007 06:28:41
Looking to buy a small dozer about the size of a John Deere 350/450 with 6 way blade and winch. What other brands and models are good that size? I see a few Komatsu"s that seem to be at a good price, are they any good? How about that little dozer from China, anyone have any luck with those? Looking to spend between $8000 to $15000. Live in NY State. What are things to look for when buying a used one? Thanks for any help. Ash
bob plumadore
10-09-2007 18:34:03
 Re: looking to buy a used Dozer in reply to Ash, 10-09-2007 06:28:41
Being a cat man I would suggest a D3 or D4. I didn't knwo about Deer's reman operation
that would be an Idea cat should consider of. A lot of my customers are still running 955s, 951 & 941s.
jdemaris
10-09-2007 07:10:07
Nobody in the USA makes a 350 or 450 sized dozer anymore. That's why Deere started buying back 350s and 450s and refurbishing them for resale under the "Certified Relife" program.
In regard to foreign makes, I've heard some good things about the Italian Landini crawlers.
I've worked for many Deere dealers in New York State. We found - that if you wanted to buy a used small crawler in New York - the machines tend to be in much better condition if bought from "down south", like lower NY black-dirt farming areas, Long Island, or New Jersey. That - because they have softer dirt and less hard pan - and fewer loggers who tend to tear crawlers apart.
The last dealer I worked for was in Oneonta, New York on the borders of Delaware and Otsego Counties. We had a fleet of rental 350s and 450s - and they often got used by loggers and guys with small rock quarries. They tore those crawlers to pieces - especially the 350s. Same goes with backhoes since we have so much rocky hard-pan soil around here.
Tigerhaze
10-09-2007 09:15:30
 Re: looking to buy a used Dozer in reply to jdemaris, 10-09-2007 07:10:07
Hey JDemaris-
Why do you think that none of the major tractor manufactures make a small crawler anymore? It seems like there is a market for them- I guess maybe the skidsteers today would be too much competition?
jdemaris
10-09-2007 09:28:11
 Re: looking to buy a used Dozer in reply to Tigerhaze, 10-09-2007 09:15:30
Good question that I cannot answer for sure. I assume that there's not enough profit in it.
Several state conservation agencies throughout the country have regs that require #1 using a US made machine - and #2 crawlers must be under a certain weight-class. Since there are NO new US crawlers that meet these specs - Deere came out with the "Certified Relife" program. State of Michigan DNR bought many - and it's pricey. If, lets say you want a "new" Deere 350 - it goes like this. First - you must have one to trade in - and it has to be a C series or newer. Then, Deere updates it - including putting in a new 179 engine - and a new serial # tag - and charges around $65,000 for it. So, total cost is $65,000 plus the value of the original crawler - and - you do NOT get the old parts back. Many states have bought 350s and 450s this way. Our tax-dollars hard at work, I guess?
I wonder where all those old parts are going - like 152 and 164 diesels, torsional isolators and flywheels, final drive parts, rollers, etc.?
U9 U9 CAT
10-10-2007 20:35:18
 Re: looking to buy a used Dozer in reply to jdemaris, 10-09-2007 09:28:11
Ok, what is a torsional isolator???
Had to ask
jdemaris
10-11-2007 05:26:24
 Re: looking to buy a used Dozer in reply to U9 U9 CAT, 10-10-2007 20:35:18
The torsional-isolator is the main failure point in 350Bs and 350Cs. I had to fix hundreds - often on service calls where a fairly new machine had died in the middle of a job somewhere. It is a convoluted assembly of springs, posts, a damper-plate, etc. that attach to the engine flywheel and couple to the hydraulic-reverser. The springs tend to fly off, get stuck between the flywheel and castings - and sieze the engine.
The 1010s and early 350s used a conventional spring-dampened clutch disk instead - and it worked fine. But, starting with the 350Bs, Deere used the "torsional isolator" instead. When the 350D came out - it was finally eliminated and a totally different setup was used - and it is much more reliable.
The older 350s can be updated - but it requires a new flywheel as well as the other new parts.
U9 U9 CAT
10-12-2007 21:16:51
 Re: looking to buy a used Dozer in reply to jdemaris, 10-11-2007 05:26:24
Thanks GOOD info..
