Cat 933G
Rick
12-31-2001 19:35:44
Cat933G track tension spring broke and I want to replace it. I have a replacement spring but lack the know-how. Do I have to open the track or just relieve the adjuster to swap the busted for new??
Earlkj
11-27-2004 15:40:57
 Re: Cat 933G in reply to Rick, 12-31-2001 19:35:44
I am looking for the complete tensioner for the track on my 933g left side - I had taken it in for new seals and they cut it apart with a torch and now I don"t haver anything
Martyn Williams
02-20-2004 03:44:19
How many CAT 933Gs are still in use or have been restored?I have a 933G 42A ser no 9034,Can anybody tell me when this machine was shipped to the UK? thanks
Dave N
01-01-2002 06:23:06
Break the track remove the the track tensioner. But be very careful check to see that the bolt that holds the spring in tension is not broken you should be able to move the spring in its holder a little bit if you cant then you need to cut the coils untill the tension is removed. Messing with this spring is VERY DANGEROUS it is under 10 to 20 tons of preload. and can kill you or someone else in a split second. I have seen them fly apart even if you drop it after you have it out. I have been working on dozers professionally for 27 years and I am scared every time I do one.If you dont know what you are doing I would let some one else do it. PLEASE BE CAREFUL Dave
