1010 steering problems
D.G. Record
05-16-2007 07:13:28
I purchased a 1010 for my dad to use on his lot. The left steering lever works great, pulls eazy and steers perfect forward and reverse. The right lever pulls harder, steers great forward, but works when it wants to in reverse. If you pull real hard, the crawler gradually turns, but it just wont grab like the other one. Any sugestions? I thought it may be out of adjustment, but that should affect forward and reverse.
CHinNY
05-17-2007 02:46:34
 Re: 1010 steering problems in reply to D.G. Record, 05-16-2007 07:13:28
Try adjusting if that fails tear it down and see what is wrong. If it is oil it will just keep giving you problems if you spray anything in there use Brake clean . If you need parts i have them just email me for my link.
original possum
05-16-2007 13:58:35
If it is adjusted properly then the problem is most likely an oily brake band. If you spray some non-flammable choke cleaner on the drum while moving slowly and exercising the brake you may recover some function. It will help until the oil comes back. You will eventually need to pull the final and fix the seal.
JF in CT
05-16-2007 09:34:44
D.G. Wrote;'I thought it may be out of adjustment, but that should affect forward and reverse.'
Not necessarily. While helping my friend with his 1010 I noticed the brake is a "band" type which tend to be "self energizing" in one direction. Looking at the pictures that direction would be forward.
JF
