john deere 420c
andrew 135
05-13-2007 13:59:50
thinking about buying a 420c was wondering what to look for and how much one is worth in running shape.it needs a lot of cosmetic work and chains and sprocket.are parts hard to get? thanks
JDknut
05-16-2007 03:56:41
 Re: john deere 420c in reply to andrew 135, 05-13-2007 13:59:50
Lavoy has good points, he is the authority on JD crawlers. Also, you might check the steering clutch housings for cracks, as mine was cracked. Another source for parts is Stone and Parrish of Pennsylvania. They part out two cylinder crawlers all the time and I have had good dealings with them.
Lavoy
05-14-2007 07:11:11
Sprockets are no problem, you might be able to rebush your old rails. If not, used rails are around. Look at the final drives to see if the tops have been blown out. Look in steering clutch housings to see if the clutches are oil soaked, if so you will need clutches, and fix the oil leak.
Lavoy
