4 cylinder Cat 933 taxcavator
mocus
03-08-2007 09:42:06
I need a head gasket for 11A 3588 4cyl diesel engine. It is around 1960 model. Have located a remanufactured head. Anybody know of a source for these head gaskets. Found one but price is 240 bucks. Maybe that is going rate, but it seems high. If that is what it takes to get good quality gasket, I will do it, but don't want to get taken and would like to find another source.
randy448
03-11-2007 19:35:11
 Re: 4 cylinder Cat 933 taxcavator in reply to mocus, 03-08-2007 09:42:06
check price at Cat dealer, they were half of price at local auto supply store-Victor brand gasket set I think.Something about the sales quantity Done this on older D4 about 4 years ago.
RAB
03-08-2007 13:25:46
Can"t help with the gasket, but am just asking what you found damaged when you pulled it down (after the over-speed episode?).
Regards, RAB
mocus
03-19-2007 13:50:42
 Re: 4 cylinder Cat 933 taxcavator in reply to RAB, 03-08-2007 13:25:46
burnt exh valve.
Bob Plumadore
03-08-2007 10:22:01
NAPA has the gasket but you will also need a set of rubber seals. I would spend the 240 and get the valve grind gasket set at Cat.
I have a 933 service manual if you need any info
VaTom
03-09-2007 05:29:25
 Re: 4 cylinder Cat 933 taxcavator in reply to Bob Plumadore, 03-08-2007 10:22:01
As long as we're on the subject, any idea where I can find a tranny gear for my 933? Need the last one, a spiral that's part of a splined shaft.
Great tractor, eager to put it back to work.
hectorgemme
03-09-2007 09:00:14
 Re: 4 cylinder Cat 933 taxcavator in reply to VaTom, 03-09-2007 05:29:25
If you have the part number maybe I have that gear because I dismantle 2-- 933 .
VaTom
03-09-2007 17:49:00
 Re: 4 cylinder Cat 933 taxcavator in reply to hectorgemme, 03-09-2007 09:00:14
It's a 3K6504, according to my parts book, used starting with 42A2106 and going on through 42A3291.
hector gemme
03-10-2007 09:25:21
 Re: 4 cylinder Cat 933 taxcavator in reply to VaTom, 03-09-2007 17:49:00
I am sorry this pinion shaft ben sold.
