955 track loader
ben brown
01-29-2007 17:00:14
friend today fired his loader up this am it was 10 degrees mud in tracks went about twenty feet said he heard a big bang track went slack rolled off. called me wet down put track back on then split the track found he had split the track tenser clynder all the way, from end to end. so frozen tracks full of mud not a real good idea. un less you the one getting paid to fix it.
Case450
01-29-2007 18:56:28
 Re: 955 track loader in reply to ben brown, 01-29-2007 17:00:14
I almost ran my tracks the other day, i got on the machine to move it out of the way to a different parking spot. The whole machine was sitting under about eight inches of snow including the tracks. I reached for the shifters and I thought I better check if the boys cleaned them tracks before parking it. I dusted off some snow and the entire undercarriage was litereally packed tight with mud from the last job in the fall. had to rent a jackhammer to free the tracks.
Bob/Ont
01-29-2007 18:47:41
Ben, wasn't that the one that needed resealing a month or two back? It likely had a crack in it from before. Could have been worse, might have taken out a final drive. Later Bob
ben brown
01-29-2007 19:50:48
 Re: 955 track loader in reply to Bob/Ont, 01-29-2007 18:47:41
no the one i re sealed was a 750jd. also did a 450 case i owne while back
