420 jd trans oil
troy21
12-11-2006 20:27:46
420 jd.. transmission fluid.. how do i chang this and were is the feel plug or dip stick.. and do i use the jd hydro oil.. or can i use a universal from say t.s.c..
Lavoy
12-11-2006 20:43:42
 Re: 420 jd trans oil in reply to troy21, 12-11-2006 20:27:46
The drain plug is down under the belly on the LH side, would be below the LH foot rest as far as location. Fill plug is on the RH side of the case, about at your heel as you sit on the crawler. Fill it to the edge of the hole.
Use gear lube in whatever weight you prefer or is appropriate to your climate.
Lavoy
