Block heater 580 Super E
bhb
10-14-2006 16:00:19
I would like to install a block heater on a 580 Super E, but I can not find a plug on the block to install the heater. I found a plug on the head that may be a spot to install the heater. Has anyone put this type of heater on and is the head a good place to install it.
Bill
JD dozer mike
10-17-2006 09:36:29
 Re: Block heater 580 Super E in reply to bhb, 10-14-2006 16:00:19
You can also get "inline " heaters from NAPA. you cut the lowest radiator hose and clamp the heater in.
just 580's
10-14-2006 19:11:45
The OEM block heater location is in the hole behind the fuel filters.
Take off the fuel filter(s), remove the freeze plug and install the block heater.
