Massey 400 dozer
Bill T in Ga
08-22-2006 02:37:53
Would like to know what kind of oil is recommended to be used in the torque converter/ hydraulic reverser.
murray
08-24-2006 18:20:28
 Re: Massey 400 dozer in reply to Bill T in Ga, 08-22-2006 02:37:53
We have a MF400 and we also have the shop service manual for it. The MF-1110 is the recommended oil. But we just use tractor transmission fluid (the hi-tran type) with no problems. If you have any technical questions I could look it up in the service Manual for you. I usually hangout over on the OT board but sometimes check in here. This is the board I started on until Kim added the OT board.
Walter Thompson
08-22-2006 13:31:29
I have a 200B with a hydraulic reverser. The manual calls for M-1110. If you do a search for spec M-1110 you will get several options as far as brand names that are compataible.
hth.
Waltmo
