580 SUPER E
DANIELLE
07-20-2006 19:57:30
IM LOOKING FOR A WIRE DIAGRAM FOR A 1987 CASE BACKHOE 580 SUPER E. WONT START INSTALLED NEW IGNITION AND STILL NO START HAD IT TURN OVER ONCE WITH THE OLD STARTER WHEN I CROSSED THE WIRES...STILL NOT SURE WHO I DIDI THAT PLEASE HELP
ajk
07-21-2006 14:21:13
 Re: 580 SUPER E in reply to DANIELLE, 07-20-2006 19:57:30
Sorry I don't have a wiring diagram.
AJ
DANIELLE
07-21-2006 15:19:20
 Re: 580 SUPER E in reply to ajk, 07-21-2006 14:21:13
I CHANGED THE IGNITION CHANGE THE RELAY NEAR THE SILINOID WHICH WIRES OR COLOR OF THE WIRES SHOULD I SWAP. I DID CROSS WIRES AND I ACCIDENTLY STARTED IT BUT NOW I DONT KNOW WHAT WIRE IT WAS.
DANIELLE
07-21-2006 14:44:44
DO YOU KNOW WHERE I CAN GET ONE
THANX
ajk
07-21-2006 01:02:05
The 580E is fitted with a Borg Warner shuttle box,the box has to be in neutral for the starter to work,there is a intermittent switch fitted to the box with two wires connected to it,check to see that the switch is not loose and that both wires are on it,it is on the right side of the box looking forward,for a test you could put the two wires together,under the flap in front of the windscreen there is two relays,one is for the starter,swop them over as they are the same,to start the engine by bypassing the starting circuit and with the machine out of gear and the key switched on cross the light wire on the starter motor solenoid with the main battery cable.
Good luck
AJ
danielle
07-21-2006 13:40:40
 Re: 580 SUPER E in reply to ajk, 07-21-2006 01:02:05
THANK YOU FOR THE INFO I STILL NEED A WIRE DIAGRAM FOR 580 SUPER E BACKHOE CASE. IF YOU COULD HELP THAT WOILD BE GREAT ANY INFO ABOUT DOWNLOADING ONE WOULD BE GREAT HELP THANX AGAIN
EMAIL [email protected]
