410 backhoe
JohnDeere Jim
06-20-2006 20:11:57
My 410 backhoe will build a lot of hydraulic pressure running with out using the hoe or loader.It actually broke the hydrulic pump shaft off.If you run one of the control valves it stops the pressure right away,but will start again as soon as you let off the control valve.We replaced the destroking valve and the pressure controle valve spool and spring.Hope someone has an idea of what to do next?Thanks Jim
Roy Suomi
06-22-2006 19:24:10
 Re: 410 backhoe in reply to JohnDeere Jim, 06-20-2006 20:11:57
OK .how do we know it's got lots of hydraulic power?? Did the splines wear out or strip out??? Did the pump drive break because of something left loose?? Whats the pump stand-by pressure??A good place to start is checking stand-by pressure....Should by approx 2350 psi running at approx 1500 rpm..[ top test port on the side of hydraulic pump front cover ] Adjustment is on the bottom of the front cover [ jamb nut with allen screw ] back it out if pressure is too high. turn it in if too low.Do you have a book for this machine?? . It would help to understand how this system works..when you pull a control valve and nothing happens , it sounds as if the pump quits making oil..Whether it's something bogus in the front cover of the pump or maybe the transmission isn't making enough charge pressure to feed the pump adequately..
