450 case crawler dozer
Dozerboy Bills
06-17-2006 05:07:04
I hope someone out there can help me with a small
problem i'm have with a 1974 450 case. The unit has been working fine untill lately.When I shift from low to high the unit will run along fine and then stop. The right track is justlike it locked down. You can then shift back to low and all works will. When the unit locks it will stall the converter and driveshaft. You can still use the left stick to turn the unit but when you use the right stick to turn it will lock down. All help would be appreciated. Thanks
dozerboy
06-30-2006 17:35:28
 Re: 450 case crawler dozer in reply to Dozerboy Bills, 06-17-2006 05:07:04
I have replaced the control rings and Hyd.line also. I stilll have the same problem. I talked to a case service man the he told me to check the control valve. I found no problems that are visible. Anyone out there that may be able to help me with this problem. Mr George has helped a lot.
Thanks Chris
george md
06-22-2006 20:43:43
Put a phone # in the email and I'll call .
george
Dozerboy
06-22-2006 18:18:03
Mr. George I hope you answer back. I got the cover off today
an found that enther one of the rings are broken. I'm going to replace them while i'm into it now. Can they be wore enough that it will cause this problem? Looking forward to hearing from you.
Thanks C. Bills
dozerboy
06-18-2006 06:26:09
Is this something I can repair without to much trouble? Is this located at the rear of the housing behind one of the four bolt on caps? Thanks for your help with this problem.
george md
06-18-2006 11:45:14
 Re: 450 case crawler dozer in reply to dozerboy, 06-18-2006 06:26:09
The cap on the rear of the trans is for forward and reverse , there are two one the front of the trans case for the high and low ,you need to pull the one on the right .
george
Dozerboy Bills
06-18-2006 14:20:46
 Re: 450 case crawler dozer in reply to george md, 06-18-2006 11:45:14
George the way i read your note to me is i need to pull the cap off on the right side in the front. This is were i will find the o-rings that i need to replace. Thanks George for your help. I have a manual to help me with this but please check on me every now and then. I will let you know how i'm doing with it. Thanks again
Dozerboy
george md
06-18-2006 14:37:58
 Re: 450 case crawler dozer in reply to Dozerboy Bills, 06-18-2006 14:20:46
They won't be O rings , they will be oil control
ring ( muck like a piston ring but with hooked ends. If you get in trouble , send me an email with a
phone # .
george
Dozerboy
06-18-2006 17:09:59
 Re: 450 case crawler dozer in reply to george md, 06-18-2006 14:37:58
Thanks George for the help I will be taking it apart this week. If I run into any trouble I may
have to trouble you again for help.
Thanks
george md
06-17-2006 10:06:09
bill,
Sounds like a broken oil control ring on
the end of the clutch shaft , there are 2 rings
there and it is the outer one that separates
the oil pressure from the other clutch . If the
inner one breaks it drops the clutch pressure ,
but doesn't engage both clutches at the same
time .
george
