IHC 500C Engine oil
Ben in CentralK
05-14-2006 07:36:18
Need to get dad"s 500c crawler running after sittin in shed for 15 years. Checked the engine oil and found it to be overfilled and gray (water). My question, what is the oil capacity of the 4 cylinder deisel.
KenNEWI
05-18-2006 14:07:34
 Re: IHC 500C Engine oil in reply to Ben in CentralKY, 05-14-2006 07:36:18
With filter change it is 8.5 US QT. The milky gray oil you have in there now is oil that has been diluted with antifreeze. This leaks out of the o-ring seal on the bottom of the piston sleeve to the block. If you are lucky, you might be able to put a can of stop leak in the radiator to seal the o-rings up. Good luck
Ben in CentralKY
05-14-2006 17:14:06
I should have looked closer!! What is the engine oil capacity for the three cylinder deisel?
hectorgemme
05-14-2006 10:21:04
HI The 500c have a 3 cylinder and if yours have a 4 cylinder you need 4 imp.quarts including filter and that should a tdc5 500.
