Main pulley nut stuck-Case 188d
alexanderson
05-03-2006 16:53:34
This nut turns onto the crankshaft and is recessed into the pulley. It has a 1/2 inch square drive female. I locked the crank by using the fan pulley bolts, then used a three foot breaker and all my strength. Then tried an oxy acetylene torch to heat the nut. Won't budge. bent the pulley bolts to near braking. I could step up to a 3/4 breaker bar, but don't know how to hold greater force on the crank, or if this is a bad idea. Pulley is aluminum. Engine is in frame (dozer)
TimBinWV
05-04-2006 16:25:38
 Re: Main pulley nut stuck-Case 188d in reply to alexanderson, 05-03-2006 16:53:34
Are there any threads showing through to be sure it's right hand threads? Try tightening it a bit ,anyway. Also,smack it with a hammer,while you got it torqued.
alexanderson
05-04-2006 16:50:46
 Re: Main pulley nut stuck-Case 188d in reply to TimBinWV, 05-04-2006 16:25:38
Got it by locking the flywheel throught the starter hole with a piece of spring steel and vice grips to hold it in place. Used a 3/4 breaker bar and a pipe. Popped right away. Thanks for all the advice.
U9 U9 CAT
05-03-2006 22:26:30
The key is to take the time to get a good stop on that flywheel. Good luck
jdemaris
05-03-2006 18:13:16
I had the same problem with the last one I pulled apart on an 60s 580CK. I finally got mad at it - pulled the starter out and wedged a pry-bar against the flywheel teeth - and then put a 1/2" to 3/4" adapter on the nut along with a 3/4 breaker-bar with a pipe on the end of it. Gave it one yank it came loose just fine. You could also heat the nut orange and then pour cold water on it - but that will ruin the temper of the nut.
I was afraid at the time that it might be a left-hand nut - but it wasn't.
alexanderson
05-03-2006 16:59:07
Correction. Pulley is steel. I guess cutting the pulley and the nut is possible, but risky,
