1845c adjustment
pepper boy
04-11-2006 08:27:55
I have a case 1845c skidloader that has been running good until the other day. I was doing some grading and all of the sudden the left side became considerably weaker while backing up. Are there any adjustments that can be done? I looked in the shop manuel and it said to remove the plug for the servo and see if it is clogged but the hex plug is stripped and I can"t get it out. Any ideas to fix this problem? Thanks. Scott.
2x4
04-11-2006 21:58:30
 Re: 1845c adjustment in reply to pepper boy, 04-11-2006 08:27:55
Scott, at the top of this page are a couple of search boxes. In the left box, type in 1845c & hit "Go". Down about item # 20 is a similar problem. Check out as many items as interest you.
