623 scraper
ricedaddy
03-23-2006 18:33:35
Do'es anyone have a preference on radiator flush and do they work? This is a 3406 cat, need a couple days before I can shut down to pull the radiator!
thanks in advance
Ron
Bob/Ont
03-23-2006 20:09:20
 Re: 623 scraper in reply to ricedaddy, 03-23-2006 18:33:35
Is this the engine with the fuel in the coolant? or is it just over heating?
Later Bob
ricedaddy
03-24-2006 21:02:24
 Re: 623 scraper in reply to Bob/Ont, 03-23-2006 20:09:20
Bob, different engine, I flushed the devil out of it today, tightened the belts and blew it out, we'l see tomorrow
Thanks
Ron
Bob/Ont
03-25-2006 18:59:01
 Re: 623 scraper in reply to ricedaddy, 03-24-2006 21:02:24
Don't push it too hard Ron, Make sure the pressure relief valve is good and get it rodded out soon if it still runs hot. What did you find with the other engine? The fuel adapter in the head only applies to the older small capsul nozzels not the long pencil nozzels. Check any fuel heater it may have first.
Later Bob
ricedaddy
03-25-2006 20:04:07
 Re: 623 scraper in reply to Bob/Ont, 03-25-2006 18:59:01
Bob, on the first 3406 (diesel in radiator)I couldn't find anything, I think he was seeing things! On the 623 we determined today the engine(temp) is not what the gauge says.We are working at 7500 ft, above sea level which water boils at about 180 degrees. So Monday we'll put on a new sending unit, thermostat and gauge. Thanks for you're help
Ron
Bob/Ont
03-26-2006 18:41:55
 Re: 623 scraper in reply to ricedaddy, 03-25-2006 20:04:07
AND ANTI FREEZE too Eh. It increases the boiling temp. Make sure the relief valve is good too that also increases the boiling point.
Later Bob
ricedaddy
03-28-2006 09:18:26
 Re: 623 scraper in reply to Bob/Ont, 03-26-2006 18:41:55
Bob, I found the problem was in the gauge, thanks for your help, it's up and running like a scalded dog now (-:
Thanks again
Ron
Weedsabate
03-23-2006 19:22:59
Well for what its worth, last time I had my KW in the shop, Cat powered, they used a cup of Cascade dishwasher detergent. Said it was good for rust and gentle clean. I would disolve it first, they didn't, seems to me that it would be better to be liquid so that it won't plug things up worse..
