64 john deere 2010 diesel crawler
PL
02-05-2006 06:34:38
I am looking for a parts supplier for a rebuild kit and I need a sleeve deck with pistons. Can I pull the engine and have it bored .020? I noticed in the parts books I could buy oversize pistons. Okla. Thanks
ben brown
02-05-2006 10:50:33
 Re: 64 john deere 2010 diesel crawler in reply to PL, 02-05-2006 06:34:38
i have a sleeve deck with piston it in good useable shape. e-mail me if instered ben
PL
02-06-2006 18:10:23
 Re: 64 john deere 2010 diesel crawler in reply to ben brown, 02-05-2006 10:50:33
Yes, I am interested how much wear and why was it changed out.I hope no cracks or warped deck plate. Quote me a price and shipping to Zip 73401 okla. Paul
jdemaris
02-05-2006 06:56:17
I don't believe anyone has ever had an engine kit for 1010s or 2010s. Deere never did. Parts are bought piece by piece. The 2010 diesel is one of the few engines that has oversize pistons available, so yes, the sleeve deck can be bored. You might want to figure up all the costs though, and find out if it's worth it. You can still buy a new standard size sleeve deck and pistons, the new deck is probably around $700 from Deere, and pistons $75 apiece. You also want to be sure the old deck isn't cracked. Last 2010 diesel I did, I used a new sleeve deck and rebuilt the old pistons. Rebuilding the four pistons cost me a total of $30 - that was to regroove and install shims. If the pin holes are worn, or the skirts bad, then it's not worth the bother. By the way, you don't have to pull the engine to bore it. Just pull the sleeve-deck out of the block.
diggerdozer
02-05-2006 06:55:36
??U can get the parts from JD
