450 case wont move, no trans pres. no tc pressure
mtdpl
11-05-2005 15:18:06
hello. i have a brand new to me 74 case 450. I had been working for a few hours when i wrapped a piece of fence in my tracks. I stopped machine and got off to try to get it out. when i started the dozer back up, it wouldnt move, and trans oil pressure was at 0, torque converter pressure at 0. It starts and runs fine, blade and winch both work, but i cant get the darn thing to move at all. Any ideas on what the problem could be would be greatly appreciated. thanks
marlowe
11-07-2005 15:48:38
 Re: 450 case wont move, no trans pres. no tc pres in reply to mtdpl, 11-05-2005 15:18:06
are you getting oil flow on the discharge side of charge punp ??
TimBinWV
11-06-2005 14:21:55
Be sure to check that you didn't bump the HI/Low shifter thats on the floorboard to left of center.(I think).
marlowe
11-06-2005 17:21:48
 Re: 450 case wont move, no trans pres. no tc pres in reply to TimBinWV, 11-06-2005 14:21:55
he would still have preasure on the gauges
SteveGr
11-06-2005 09:11:51
Did you start the machine in gear, in otherwords with out all the levers being in nuetral. If you did you tripped the safety that some crawlers had. You either have to bring the levers back to nuetral or shut the machine off put the levers in nuetral and restart it should work then. P.S. you do have the flipper for the start button yet on your directional steering clutch control right.
marlowe
11-06-2005 09:57:05
 Re: 450 case wont move, no trans pres. no tc pres in reply to SteveGr, 11-06-2005 09:11:51
in 74 they did not have that safety junk on them
John Van Valkenburgh
11-05-2005 19:53:56
Marlowe has some good suggestions. I would add that you should check for a collapsed hose at the same time. You might even have something pressing underneath that would kink up a feed hose.
Best of luck,
John
MARLOWE
11-05-2005 17:16:05
sounds like you lost the trans oil or you ripped the line to the charge pump of or have a hole in it it's on the right side of the engine most of it is steel but has a rubber hose on the end under the floor borads it might have come of or lose it's a suction line so a little leak will stop you
matdpl
11-07-2005 14:44:40
 Re: 450 case wont move, no trans pres. no tc pres in reply to MARLOWE, 11-05-2005 17:16:05
Thanks for the suggestions. I replaced the short rubber line going from the tranny (i think) to the charge pump, but still have no pressure in either the trans or t/c. I did fill untill the dipstick under the seat read full, but i havent been able to get pressure yet. By the way, it is in gear when i try to move, and in neutral when i start it, all other simple fixes of that style have been checked and ruled out, before i tried the forum. thanks again
mtdpl
