371 Detriot Questions/HELP...
Beakeeper
09-20-2005 04:00:10
Brought home a Clark Michigan 55lll- seems to be among the first Clarks.. with 371 Detroit to play with. Been setting 10 years. With a shot of starting fluid with throttle to the floor she will start & fast idle/won't rev up. Obviously the first step is to drain fuel & change the filter.../Done that/2 filters... The questions- There are 2 factory stickers on the dash. I suspect they are on all machines & may or may not apply.. 1st is the standard warning about letting it idle 3 minutes before shutdown to cool the turbo. I'm not real sharp with a Detroit but I see no turbo. 2nd sticker says to start the machine you pump up the diesel pressure & you may have to continue pumping until the engine warms up. That confuses me... Maybe that is a part of my problem. I see a knob with a cable behind the seat that runs down to the left side of the engine mid height to the block. Knob pulled it seems to trip something with about a 3 inch handle that pops up...a kill knob of some kind? It needs to be reset at the end point by hand once pulled.. Then on the right side top of the block is the remnants of a cable going to something to do with the fuel. If I work that back & forth by hand I feel resistance for half the stroke kinda like it may be a hand fuel pump? ( it's not in the air intake/not a choke type diesel shutdown ) & I have no idea what that does. Anybody have one of these little Detroit loaders or any Detroit wiz's out there that can help me out. One more symptom.. The radiator is still full of anti-freeze. No whiteish tint in the engine oil. Machine was said to be operating fine when parked. When runing she alternately blows white to blue smoke. One fellow suggested that was a sign of fuel system sucking air.. Any ideas on that? THANKS!!!
NC Wayne
09-21-2005 22:08:08
 Re: 371 Detriot Questions/HELP... in reply to Beakeeper, 09-20-2005 04:00:10
Hey Beakeeper, I'm not sure from what your saying if you've actually had it running or wether your still trying to get it to run. I say this because in one place you say it starts on ether and revs up then dies, but in another you talk about it smoking when running (possibly what is was doing when initially parked years ago) ???? So I'll adress everything as well as I can and hope I cover what you need. Like the others have said the spring loaded lever that goes into the intake snorkle is an emergency shutdown. It's main use is to shut the engine down if the rack shutdown doesn't work, or, God forbid, you choke the machine down and the engine restarts running backwards. I don't know what the other knob is for. A 71 series Detroit shuts down by utilizing the rack to destroke all of the injectors to a zero fuel position. If you were to try shutting it down with a soleniod/mechanical valve on the fuel line going to the injectors the engine would continue running til it ran out the fuel already in the lines to the injectors as well as in the injector bodies. When the fuel in the injector bodies was gone the injectors would be running with no lubrication. Running out of fuel on occasion usually doesn't cause a problem, but doing it on a continual basis to actually shut the engine down would cause alot of premature wear to the injectors as well as making the engine take an indeterminate amount of time to actually shut down. If the second knob is for something like this you need to get rid of it. As for it being for some type of primer pump, etc I doubt that too. A Detroit utilizes a gear type, positive displacement fuel pump driven off one end of the blower. So no primer pump should ever be needed as the pump is self priming. Your right on the fact that there is a return line also. The fuel flowes into a passage in the head (or in external pipes on the really old designs) and from there through "external"lines under the valve cover and then into each injector body. From the injector what fuel doesn't get used, which is the majority of it, is returned to back to passages in the head, through a orifice which keeps pressure on the injectors, and then out through external piping back to the tank. Look for the lines screwed into the head on the opposite side from the exhaust and those are gonna be your fuel lines. As far as the rack being stuck if you can start the engine and it will go completely through the speed range from low idle to top end and back then the rack isn't stuck. The "rack sticking" usually isn't the actual rack at all, but a plunger in one of the injectors sticking. The amount of effective stroke each individual injector takes is "timed" by adjustments on the rack so they are all equal. So when one plunger sticks all of the others are tied to it via the rack so they are all held in the same position When a plunger sticks the engine, typically, will only run at one set speed. Rarely it will rev up or idle down from that stuck position, but not both. On the subject of the smoke, a Detroit has two oil control rings at the bottom of the piston that have almost a razor edge. After setting 10 years I'd just about bet at least one or more of them are stuck. OK, going on the assumption you haven't actually had it running yet. With a shot of ether the engine will rev wide open, til the ether is gone, and then die just like your saying. First, find the two fuel lines I talked about earlier. Unhook the return line (the one not coming through the pump), spin the engine over and make sure your indeed getting fuel to the injectors. Now assuming you have a fuel flow look for the lever on the governor housing where the throttle hooks up. Unhook the throttle cable/rod and make sure it has a full range of motion. It may be something has the throttle stuck in the shutdown position, so check to make sure the rod is moving. Look at which way the rod/cable moves the lever when you push the peddle to the floor. Make sure the lever on the governor is going all the way in the same direction also. Now holding the governor lever in a position where you know it should have fuel try starting it again and see if you get any smoke at all. You should get at least some smoke if your getting any fuel at all. If your not seeing anything and the engine still isn't starting, then pull the valve cover and move the rack by hand and insure the geared shafts the rack connects to on all three injectors are all moving in and out completely. All the way in is full fuel, all the way back is no fuel/shutdown position. If one or more of the injectors is stuck then go ahead and replace all three. If you don't the new injector/s will "fire stronger" than the old ones and cause an imbalance in the load between the three cylinders which isn't good for the engine. If none of this works feel free to contact me direct at--- [email protected] and I'll be happy to help you troubleshoot as much as I can without actually being able to see it. Good luck. Wayne
mike j
09-21-2005 09:28:44
If you have not already done this you should pull the valve cover and MAKE SURE THE RACK CONTROL TUBE MOVES FREELY you may have a sticky inj. rack which can lead to catostrophic faliure of the engine (and your nervous system)also the emergency shut down is just that for emer. only use the fuel shutdown to stop engine .reason is emer flapper can suck blower seals and cause mass oil use and possible runaway. as other poster said check air intake for restriction . good luck mike
John Van Valkenburgh
09-20-2005 21:46:37
The "priming" knob-thing is new to me. You already figured out the emergency air shut off. Generally speaking there are a couple of ways the engine may be shut off. On some there is a switch which operates a selenoid that kills the fuel. Others may have a cable operated device that kills the fuel. What I'm getting at is that I'd make sure that the fuel-stop device is not partially activated. Judging from the fuel usage its probably okay.
Another obvious thing to check is the air supply/filter. If you have not already done so, make sure its clean.
The blue and white smoke worry me a bit and I'd wonder if you've got a blown ring or piston. Look for engine oil collecting in the exhaust or signs of really excessive blowby. Its been my experience that Detroits typically drip oil out the breathers especially at idle. This would be normal, but oil collecting in the exhaust would not be normal.
The engine may not have a turbo but it does have a blower that needs to cool a few minutes before shutting down. I never minded the shutdown wait as the sound of an idling Detroit Diesel is one of my favorite sounds. Actually most any sound the old 2 stroke Detroits made were pretty good, but the idle was like a kitten purring to me.
Best of luck,
John
woodboat dave
09-20-2005 06:36:57
You have to reset the blower emergency trip. That is the cable you are talking about. If you look at the supercharger on the side of the engine, it will have a spring loaded lever with a mouse trap like catch on it. You must reset the lever on the catch. This is the air shutoff valve. The engine will start sometimes with it closed but will barely run.
Dave
Beakeper
09-20-2005 15:53:05
 Re: 371 Detriot Questions/HELP... in reply to woodboat dave, 09-20-2005 06:36:57
THANKS DAVE!! That little lever is no longer a mystery. Unfortunately not the whole problem... It's not tripped... If I pull the cable the little reset lever pops up/is spring loaded... I reset it & theres no difference/same as before though I did not attempt to run the machine with it tripped as it seemed to be the logical function of the run position pushed back against the spring presure & held by the trip. I did take the suction line off the fuel tank & stuck it in a gallon can of fresh diesel & with fresh fuel in the filters ( and some anti gel additive ) I started her up & she fast idled blowing white & blue smoke. Just as it started to rev up & blow black smoke the exhaust again turned white & blue & she quit... Sucked the 1 gallon can dry in seconds. Must be a return line to the main tank I have not found yet... But I think I'm on the right trail?????
Jerryh
10-08-2005 12:21:45
 Re: 371 Detriot Questions/HELP... in reply to Beakeper, 09-20-2005 15:53:05
I had a motor doing the same thing. After just about giving up I took a flashlight and looked down in the intake area of the blower and it had been packed with mud from dirtdobbers. Have no idea how they entered but must have been a small hole somewhere. Cleaned the dirt out and ran perfect.
