Allis 940 loader
Bernard le m�ca
08-24-2005 18:42:33
Hi, a friend own a 940 Allis wheel loader. Today the loader stop moving and a bad noise come from the rear of the engine. It have a Deere, 4 cyl, in the loader. Does the 940 have a rubber damper, like a coupler, in the flywheel. Thank you. Bernard le m�cano Qu�bec Canada
Case450
08-25-2005 09:25:14
 Re: Allis 940 loader in reply to Bernard le m�cano, 08-24-2005 18:42:33
did the loader stop moving when the noise started? usually it's the tranny that will stop the machine from moving.
Bernard le m�cano
08-25-2005 10:03:20
 Re: Allis 940 loader in reply to Case450, 08-25-2005 09:25:14
Hi,the engine is remove, it have a fiber ring-gear, that bolt in the flywheel, the internal thoot come over the torque converter ring-gear.All the fiber ring is scrap and many bolts are broken. Make some phone call for parts afternoon. Bernard le m�cano Qu�bec Canada
Roy Suomi
08-24-2005 20:29:33
Deere loaders use a rubber dampner. When they fail usually you will find a vibration and a rubber smell coming from openings in the clutch housing. I'm not sure about Allis. Any noise should be investigated. Pull that motor.
Bernard le m�cano
08-25-2005 03:39:23
 Re: Allis 940 loader in reply to Roy Suomi, 08-24-2005 20:29:33
Hi Roy, thank for the reply. I will remove the starter and check for the trouble. The engine is not hard to remove too. All the loader work fine, the torque pressure is good, the charge pump have 400 hours. Bernard le m�cano Qu�bec Canada
