Correct Hydraulic Fluid for IH500 Diesel
Barry 1950 8N
08-06-2005 08:13:23
I have a recently acquired 1969 IH500 that has the power reverser.
Total hydraulic fluid capacity is 33 quarts.
Can anyone tell me the correct fluid to use?
80w-90 or JD-20 that is used in more modern hydrostatic machines?
Charlie
08-10-2005 04:52:33
 Re: Correct Hydraulic Fluid for IH500 Diesel in reply to Barry 1950 8N, 08-06-2005 08:13:23
You can get IH Hy-Tran at a Komatsu dealer, and many companies manufacture an oil that meets the same specs. I have found differences from one to another in terms of filter clogging so I stick with the IH Hy-Tran. I would not use the other oils you mentioned.
hector gemme
08-06-2005 10:12:10
HI The transmission need HY-TRAN fuild not 80w 90. HECTOR
