case 450 track loader
ben brown
07-20-2005 15:29:47
i need a couple brake disk. two have good splines two are worn to bad to reinstall so if any one has some good used one drop me a line thanks ben
stressfree
07-21-2005 01:32:04
 Re: case 450 track loader in reply to ben brown, 07-20-2005 15:29:47
HOW HARD ARE THEY TO CHANGE.WANT TO TACKLE MINE.
ben brown
07-21-2005 04:22:27
 Re: case 450 track loader in reply to stressfree, 07-21-2005 01:32:04
not all that bad i had mine on blocks to rebuild the torque converter so i went a head and did the brakes mine needs new master clynders and slave cly. they come out the top but need to get under bottom to remove bolts so pans need to come off. you well also need to take the control plate off from in front of the seat.
stressfree
07-22-2005 01:48:50
 Re: case 450 track loader in reply to ben brown, 07-21-2005 04:22:27
i did my master clys.would like to do the disks.tell me what all you did.maybe i could save a few steps.
ben brown
07-22-2005 04:18:29
 Re: case 450 track loader in reply to stressfree, 07-22-2005 01:48:50
i had to replace ,master also first remove floor board master cly brake pedles assy. remove brake lines valve that control brake for turning. the panel that hold the controls for drive foward reverse and left and right track . emergency brake cable there are 3 1/2inch bolts that hold assy to transmission. also just any thing that is in the way like lines etc. they come out the top but well need to take off belly pan to reach bottom bolts. if you can a good cleaning of all dirt and trash helps .
