440 I fan belt replacement
Roy D
04-10-2005 05:13:02
Having a heck of a time getting new fan belt on my 440 Industrial farm tractor. What is the secret, can't find a diagram, so old, mechanics in my small town weren't even born when it was built, and nobody knows or cares that I MUST get it fixed. Been working on it two days. HELP, PLEASE
Lavoy
04-10-2005 10:03:43
 Re: 440 I fan belt replacement in reply to Roy D, 04-10-2005 05:13:02
I assume you mean the large belt from the crank to the water pump? If so, have you loosened up the outer sheave on the water pump pulley? ONce you have that done, slip the new belt over the fan blades one at a time until you have it around all 4, put it on the water pump first, then the crank pulley, and tighten the belt with the outer sheave.
If you have a crank driven oil pump, you will need to remove it to get the belt on.
Lavoy
scott in wa.
04-11-2005 13:47:26
 Re: 440 I fan belt replacement in reply to Lavoy, 04-10-2005 10:03:43
How about using the link type belts, that way you don't have to remove your hydraulic pump.
anybody know about these, or used them, how do they work???
where can I get them???
thanks
Roy D
04-13-2005 04:56:37
 Re: 440 I fan belt replacement in reply to scott in wa., 04-11-2005 13:47:26
Good idea..... ...found one at an oil field supply company....not cheap....cost $40...but will not have to remove power pump and shaft..worth it..made of rubber links,so it's adjustable..
